soapfoot
ruffrecords said:Well I was looking for low noise and microphonics ECC883/12AX7 tubes. I have a Lindos test set with a built in speaker so you can hear the noise and listen to microphonics as you tap the tube with a pencil. You can hear loose grid wires vibrating and the pings as the tube heats up and cools down.I tested dozens of NOS and current production tubes this way. The NOS tubes were very inconsistent with very few samples having low enough noise and microphonics for my purposes. I found the most consistently low noise/microphonic tube is the current production Sovtek 12AX7WB.
I feel like NOS 12AX7s are practically "over."
It's such a popular tube type that the available stock has been picked over and sorted through so many times (before the remainder is then in turn picked over and sorted through) that what's left probably isn't really a representative sample any longer.
I also get the feeling that that there are many, many tubes being sold as NOS just because they test "strong" on an emissions tester.
And of course there are old counterfeits that aren't very good. Very early in my DIY days I bought an entire lot of NOS "Amperex Bugle Boy" 12AX7s. They were lackluster older made-in-USSR tubes with counterfeit labels.
