abeLovesDIY said:I have a PM-1000 console I am restoring. The power supply is in bad shape and has missing/kludged pads on the PCB.
I am thinking about ditching it all together and swapping in one of these:
https://www.amazon.com/gp/product/B08C83C6LK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 for 48V, and a few 1N4003s to step down to 44V for the channels. But then I'll still need +12V for the headphone amp, and +13V for the lamps - It seems kludgy, but should I just use a wallwart for those?
The back of the Mixer already has two aftermarket adapters, so the holes are already there...
Whoops said:Can you write a list of all the voltage rails needed for the PM1000?
I have quite a few mixer PSUs that might fit the bill
abeLovesDIY said:+48 for phantom
+44 for the channel strips, etc..
+13 for the lamps
+12 for the headphone amp.
I have a switching meanwell that puts out 48, I was going to trim that down to 44 and use it for phantom and the channel strips.
I have a ton of 12v supplies so I was just going to use that for the headphone amp and maybe run the lamps as well, since they are only separated by a 22 ohm resistor anyway... Or maybe I'll kludge in that resistor...
