Where i can find a setreo dual Pots 10k/10k with push/pull toogle ??
EmptyMusicBox1
FRANCE LYON
Hello every one i need help to find the good Pots for a Dry&Wet compressor option  :
- Stereo Dual Pots 10k/10k with push/pull toggle ? or rotary toggle
thanks for your help :)
These are not off-the-shelf parts.
You may want to look into spare parts for car radios?
Or a simple switched pot plus a relay?
http://www.dx.com/p/maitech-8-pin-b50k-potentiometer-w-switch-green-2-pcs-318474
Jakob E.
Jakob E.
Jakob E.
Jakob E.
Thanks Jakob for your help !
andre tchmil said:
How many do you need ?
I need 1 , (2, Or 3 for spare :)  )
If just a small quantity, State Electronics (http://potentiometer.com/) will make them for you.  Be warned, they will be VERY expensive!
ALPHA make  a pot with a push pull switch. Holger used them in his mixer build. I will see if Ican find the link the the German supplier he got them from.
Hi I'm the culprit here by the way. I am working on the Crush-n-Blend again after having gotten
a lot of requests for it and want to use a push-pull pot so that it doesn't mess up panels that have
already been made by drilling holes for keyswitches.
On a different note, by the way, just got finished designing a small converter PCB to make tactile
momentary keyswitches into toggle switches (in German it's called a Schaltfolgekonverter - don't
know what to call it in English but a direct literal translation would be Switch succession converter).
The issue having been that there are a lot of way cool little illuminated keyswitches but they are
all momentary and those ones that do latch are either huge or bulky in some other way that hampers
creativity in general. Anyway, that's that.
Thanks Ian, just gonna check up on what Alpha is gonna say, the little asterisk next to the number
looks promising. Might come through with this one after all :)
Holger Classen originally told me about these. He used them in his Krassemachine. He said their web site is poor but the people are friendly and helpful.
guy_4 said:
Hello,
How about this one ?
http://www.jlmaudio.com/shop/dual-10k-log-pot-with-pull-switch.html
Guy
Looks like what he's looking for are they are in stock :)
