Where to get permalloy laminations?
sponzorb
Active member
California
I want to wind some mic input transformers, which calls for some of that high permeability / low coercivity permalloy goodness.
Where do you find these though? I’m not getting much luck searching for them. Is there a source for these that people rely on?
unfortunately getting a supplier to supply such a low amount for a small run is next impossible. I also need a small amount so I can get some trafos wound, as my trafo guy cant get them also.
I found a potential lead in the US.
ESPI Metals https://www.espimetals.com/index.php/technical-data/175-permalloy-80
They can do permalloy 80 lams. They have sheets of 0.014in thickness, and can cut them into lams based on technical drawings. I haven't gotten a quote yet, but they said there's no minimum, although cost is expectedly higher for small orders. I think I'll draft some EI and UI lam drawings and get a quote soon.
Would they have to be reannealed after cutting?
