Which distance matters most? Micpre internal wiring / traces
mkiijam
Hello, I suppose there are more than a few variables, but as general thoughts on:
1. XLR to input transformer vs
2. Input transformer to amp vs
3. Amp output to output transformer vs
4. Output transformer to XLR?
Like which node may be most susceptible to noise pickup?
2,
because it is the most high impedance situation and the signal is still small. A good example is a tube mic pre amp with a 1:10 input transformer. Impedance is 100 times higher on the secondary side than at the primary, so 2 is more prone to noise pickup than 1.
3 and 4 are less problematic, the signal is stronger and got lower impedance
I'd like to ask the same question about transformer-less mic pres.
I would guess No.1 would be input XLR to fist gain block/chip.
And No.2 would be gain pot to gain circuit.
Not necessarily. Presumably you can have many feet/meters of cable between the microphone and the pre-amp, so a few inches between the connector and the amp circuitry should not necessarily matter. Keep the wires well-twisted to prevent imbalance in magnetic inductive pickup and it should be fine. You of course still have to be sensible in routing, don't twist the wire pair and then assume it is fine to drape across the power transformer, but I would assume you aren't asking about egregious or nonsensical routing, just optimizing the usual tradeoffs of placement within the chassis.
A lot has already been said.
I would like to give more general analysis guidance.
The first part is consider the sources and mechanisms of interference and the sensitivity to interference.
Sensitivity is both basic and complex. Given the same amount of interference, the greater the signal level, the better the SNR. So on the most simple level, the lower signal levels, the greater the sensitivity to noise.
HOWEVER, noise interference (level) is NOT fixed, even if the interference source is fixed, the amount of coupling of the noise depends on mechanism and coupling efficiency.
One part is electromagnetic, magnetic fields are not shielded by the shield around conductors, instead they are best rejected by tightly twisted conductors. Coaxial cables also work well.
This extends for example to AC connections to and from mains transformers.
Magnetic fields fall off by the square of distance, so distance is the best mitigation strategy.
If magnetic interference must be shielded, usually mu metal foils, sheets or cases are needed. They are expensive and still limited. In one case my shielding solution for a low level amplifier was mild steel on the outside, then a layer of copper foil and then a layer of Mu-Metal.
Electromagnetic coupling is always b!tchy, often it can come from outside the actual unit once in a rack.
Doughnut shaped transformers (Toroid, C-Core and R-Core) are notorious for their strong vertical field when placed flat, the internal magnetic steel screw in toroid's acts as kind of a focusing device increasing field strength and making it more narrow.
Shorted turns around the outside of transformers (not inside the winding etc.) can help limit the escape of magnetic fields, by acting as a shorted turn "transformer" for the magnetic field outside the transformer. understanding of how transformers work and where magnetic fields escape containment is needed.
Magnetic field coupling gets worse with low impedances, because it's down to current flow. With infinite impedance, there is no current flow and magnetic coupling is defeated.
Of course magnetic items (such as nickel plated smd part terminations or magnetic steel wires on parts or indeed transformer cores) will act as especially sensitive receiver for magnetic fields. In this case high impedance does not help and twisting or other measures for cancellation is usually not possible.
As many passive components are magnetic, it is possible to pull out hair trying to trace the source of hum until you replace a generic part with an "audiophile" one which incidentally is also non-magnetic.
So first rule, no matter what the impedance, no matter if you have a plastic or metal case, twist all wires, consider transformer shapes, placement and magnetic fields (both in terms as source for other gear and sourced from other gear).
Second rule, place sensitive circuits in places where they are not only far from the device's power transformer, but also consider typical placement of power transformers in other gear in the same rack and don't place it where there will be a good chance of a power transformer below...
Distance, distance, distance. If required, adjust PCB layout to run hot/cold or signa/ground lines from connectors in side by side or top/bottom of PCB pairs (even with a ground plane in-between, it's transparent to magnetic fields)
Other interference is electrostatic. It is literally capacitive coupling. It is shielded by electrostatic screens. Because it is effectively "capacitor coupling", in presence of a zero impedance it is completely defeated, high source impedance and even higher termination impedance maximise this source of interference.
As the source for such coupling is usually 120V/60Hz or 230V/50Hz (nominal) the interference source is VERY HIGH VOLTAGE.
So if we have (say) 120mV signal with 100kOhm circuit loop impedance and we want 94dB SNR the coupling must be low enough to have no more 2.4uV coupled from (say) 230V. So the 230V noise needs attenuating by 160dB!
So 230V & 100kOhm @ 120mV we need to reduce coupling capacitance to 0.016pF (16 femtofarad) if we do not shield the circuit. Loose metal not grounded can act as antennae and the couple noise into the circuit.
The next thing we observe is we are back to basics, the higher signal levels, the higher SNR.
Low impedances defeat capacitive coupling but are exposed to magnetic coupling. High impedance's defeat magnetic coupling (into conductors) but maximise capacitive coupling.
Combining twisted wires and shielding will guard against both sources of interference. Starquad is even better than simple twisted pairs.
In PCB layout minimising loop areas, observing symmetric and parallel/layered running of hot and cold signal lines (remember, ground isn't) and doing so all the more where signal levels are low and shielding high impedance lines (buried on an inner layer inside a multi layer PCB) all can help making a design inherently resistant to interference.
If all else fails, self adhesive copper foil allows improvised shielding of traces, even in production, if magnetic interference in PCB traces bothers, cut them away and run twisted (shielded?) pairs of wire instead.
Thor
Oh, I forgot to add
In the design I'm considering there is a gain control in the negative feedback loop of a discrete op amp.
Slightly OT, but on the effectiveness of star quad cable - many of Audio Technica's installed sound systems have 25' of mini quad cable between their compact mic heads, which have only the FET inside, to the mic's phantom module. I've never had one of these pick the slightest bit of noise or interference. And that's loong cable between the FET and the rest of the mic's circuitry. Probably helps that AT's mini quad is braid+foil shield.
Oh, I forgot to add
Oh-oh be careful about stray capacitance. 🤔
Back in the 70s I had to locate a mic preamp's gain control over one foot away from the circuit. I generated a buffered common mode signal and drove the shield of my shielded cable with that bootstrapped low impedance.
Starquad delivers excellent noise rejection. One possible consideration is higher capacitance than normal shielded cable.
I think the gains from noise rejection in star quad cable overcome the downside of losses due to capacitance - you can fix HF loss but but you can’t fix noise. I have used star quad for many different applications and it seems to work well even for digital audio transmission without any hiccups.
Yes coaxial. The impedance does not matter below 200 kHz. For the occasional direct out mod on an older console I will use RG316 which is a high performance stranded center conductor coax. I use the single shield version.
Proximity and wire type was always a bigger issue than length inside a chassis for me, with "short as possible" being the length criterion. Component choices and front panel ergos are higher on the list than internal lengths.
The wiring of Neve 80 series modules has always been my measuring stick.
Mike
The wiring looms desk to patchbay on a lot of Neve consoles I’ve worked on are long, never had any noise issues with those - insert sends/returns for example, when you hit the insert in switch on a channel there is absolutely no difference in the silence or measured response of the channel - this can be a run of many metres round trip, more if you include the desk internal wiring. The one I am working on at the moment has a patchbay loom of 8 metres - 16 metres round trip plus console internals each way. Aux sends, direct outs all unbalanced and noise free.
Mike
I was asking in the context of magnetic interference as mentioned by Thor. Agree that the characteristic impedance etc is not of concern at LF.
