I'm working on upgrading my Behringer cx2300 crossover, which I use to split signal at 90Hz between my studio monitors and subwoofer.
Now there are BE037 all the way for audio signal, and it sounds too harsh on hi freq range for my taste.
I read that BE037 are actually TL074, and that those sound more harsh compared to 5532. So I thought I'd swap some ICs.
My plan is to make small boards with two NE5532 on each, with pins which would fit into BE037 (TL084) footprint. (Or maybe with four NE5534, lets see...) I plan to bias NE553* outputs into class A, and I may play arround with some other opamps, to see the effect. Therefore I want to stick with dual/single ICs, and avoid quad ICs. Probably I'll have to upgrade power supply, but no problem, I can make external one.
I'm just not sure if replacement of all BE037 is proper. They are FET, I guess, like TL074(84), and NE5532 are bipolar.
Crossover basically has three sections:
1. inputs and hi-pass filter
2. crossover filters
3. outputs with delay, gain, limiting and balanced output
Here is link to schematics, if it helps.
http://84.255.203.119/Berhringer%2520CX2300C%2520Service%2520Schematics.pdf
Are maybe TL074 FET better in some positions?
Outputs may be better driven by NE5532, is it? And filter (at least hi freq range) I'd also prefer to change to NE5532, or possibly opa2134. How about line inputs?
Any suggestions?
Is FET vs bipolar of any significance in such line level circuits? Besides turning arround some polarized capacitors because of changed polarity of offset voltage, is there anything else that I should be aware of?
thnx
Any suggestions?
thnx
