Hi everyone,
Just finishing up this project at long last. Power supply is currently up and running, before I plug in my op amps that I painstakingly built, I just had a couple of concerns.
All the voltages on my boards check out flawlessly with one exception: IN- on all of my boards read anywhere from 0.058VDC to 0.178VDC. The voltages seem specific to each board, for example, channel 1 always reads 0.058VDC, channel 2 always reads 0.178VDC etc. The documentation says that this measurement should be 0VDC, are these voltages within a safe margin, or should I be concerned?
Also, it seems like the V- pin on all of my boards is taking a very long time to return to 0VDC. Is this normal?
Any help would be greatly appreciated. Once i have this sorted out, I should be good to go.
