Chris-audio.com
Member
- Joined
- Jan 26, 2019
- Messages
- 9
Can anyone please tell me which power transformer to hook up to the ML12 PSU? 110in 24 out? Not really sure and want to try purchase the correct thing. thank you so much.
TillM said:Yes this will work.
But also 30va should work.
Maybe also 25va, but I’m not sure.
The ML12PSU would work with the ez1290, but you can’t take it with the ML12.
Only if you also use your ML12 with 24v rail instead of 16v.
But then you have to look, that your DOAs can take 24v.
TillM said:yes this will definitely work
redear said:When built I think they were intended to be used in VERY loud situations
redear said:It came with a power supply but it’s noisy (like it hums) so i will be building a new one of those too...
