COG (NPO) dielectric are very neutral so fine for audio paths.Didn't know that TDK produces capacitors as well.
datasheet: TDK FG series, TDF FA series
Would you include or view them as suitable these in a equalizer circuit, audio path.
2.5 mm x 5 mm
those Xicon are rather big atleast 12 mm x 5, using 4 of them would require almost require a extra pcb (in my case).
These caps are ceramic. Only the COG are suitable for "being in the signal path", so only up to 10nF.Didn't know that TDK produces capacitors as well.
Ya, but my supplier (a litle mayor trader) found that's it good enough and hang his coat definitely on the hanger and went to enjoy his pension.Those green wima (fkp?) were nice.
the E.Q. circuit i got uses one 470pF and one 560pF.These caps are ceramic. Only the COG are suitable for "being in the signal path", so only up to 10nF.
The others have too much capacitance variation with applied voltage, making them distortion generators.
there are objective metrics that describe capacitor behavior adequately. I first wrote about them back in the 80s.Capacitors are often "opinion-land" as opposed to fact based. See article below. Application is very important too. Polypropylene and all ceramic caps are piezoelectric, so if they are on a PCB inside a subwoofer, you may get PIM (passive intermodulation distortion) products, but in a mic pre, they would be fine. I'd recommend looking at the classic Cyril Bateman Wireless World & follow-up articles here: Cyril Bateman's Capacitor Sound articles | Linear Audio NL.
Those green, polyester caps are the cheapest of the cheap and I don't have any great love for them. All things being equal (and never are), PP are lower distortion than any of the polyesters. Also, using a higher voltage than needed (as in 2X or more) caps also will give you lower THD. Now, I'll have to re-read the articles to see if my memory needs a good demagnetizing and rerecording!
Careful Paul, the double blind ABX police will be coming for you soon.In the EQ circuits I have experience with the brand of like material capacitors matters. In the Igor Sontec TDK PP caps sounded much better than Wima mkp or fkp.
Yes, but in a drum machine or synth higher distortion might be a good thing.Those green, polyester caps are the cheapest of the cheap and I don't have any great love for them.
