As this is the only thread I found about the Roland JX 3P , I write here as I have one here on my table that has problems on 2 of 6 voices..
The synth gave me some headaches …
I already recapped the whole unit and found a rotten trace on channel/voice 6
That one was completely dead through this and now works perfectly.
The problems still present are on channel 1-2 for dco2 and on 1 of dco1. (you can hear the voices on a very low level means they actually work)
So the behavior is .. you switch on the unit… All voices WORK and then… the problem voices get faded out slowly.. and remain on a very low level..
With the scope there is a saw signal on IC104 pin 1 and 6 first and then gets flat slowly .. but this saw should stay stable (seen on the ICs of the other channels/voices)
It‘s like water that runs out slowly…
All is built discrete..
I already replaced the transistors around IC104 (op amp) and the op amp itself, but that did not help.
There are caps around the op amp, but when checked, they were aright…
Has someone experience with that synth? Is this a common known issue on it?
Anything else seems to work fine
Edit: Solved! I found out, the multiplexer ICs had a problem. Can‘t exactly tell what, but I exchanged IC 28 (4051) that is connected to the opamps to for Dco 1 and 2 and the voices were back loud and clear..
Also exchanged the other 4051 Ics 23, 26, 27 (connected to the opamps for VCA and VCF) just to be sure to avoid problems by them in the future.
