Mouser has the both, Vishay finished the RNX series,but there is a MOX version.Hi,
Can anyone sell these or recommend a source?
6x 60M
4x 400M
MOX200004006J
You dont need 1/2W as there is no voltage drop in the high impedance section
Neumann used custom made wirewound resistors as no modern metal films existed at that time. Wirewound has higher current ratings,but the capsule has no power consumption(you can check with electrometer it is pA or fA range)I see, thanks.
So why did Neumann specifically stated in the U67 schematics an 1/2W rating for these two resistors?
All the other resistors in the schematic are stated at either 0,1W or 0.25W, being most of them 0.1W, only the two 400M resistors are drawn with a 0,5W rating
Thank you
We have the 400M 1% 1/2 watt, in metal film. I don't have the 60M
I appreciate it, we have more of the 60M resistors on the way, they are normally in stock here. We are a studio/brodcast gear repair and fabrication facility in the Charlston SC area (East Coast, USA). There are a large number of aviation and military contractors in our area, so there is a constant supply of high grade electronics surplus parts if you know where to look and who to ask... and can be patient. We stock the high-precision, low temperature coefficient, metal film resistor types (usually Philips Brand, Roederstien or others) in many values; and some wire wound for special applications. usually Philips brand metal films. We have other parts for mics too - transistors and tubes etc... Anyway, I am glad you found some and thanks for the offer. Keep us in mind if you are looking for anything in the future - we are always looking for small parts and gear from Europe so its nice to have another friend across the Atlantic. I get over every few years, usually Germany is where I stay while I work; I've always wanted to go to Portugal hunting for gear.I ordered 10x 60M resistors, I will only need 4 I think, they should be arriving at anytime.
I can send 4 on your way, just pm me your address
Take care,
Tony
