I posted sources for the BC560 on the Bo Hansen DI thread.
Do you need only BC560? You can use also the BC559 instead of BC560 they're both low noise.
You can use any of the sources in the links below.
If you have any problems let me know since I can source them locally in my go to local stores.
Sources for BC559/560:
http://www.banzaimusic.com/BC559C.html
http://www.banzaimusic.com/BC560C.html
https://pt.mouser.com/ProductDetail/ON-Semiconductor-Fairchild/BC559CTA?qs=%2Fha2pyFadugI%2Fdi3slSIc0GMrYa3BEJ%2Fwv7khBg3L28%3D
http://smallbear-electronics.mybigcommerce.com/transistor-bc560cg/
https://pt.farnell.com/on-semiconductor/bc559cta/transistor-bipol-pnp-30v-to-92/dp/2453808?st=bc559c
https://pt.farnell.com/on-semiconductor/bc559cta/transistor-bipol-pnp-30v-to-92/dp/2453808RL?st=bc559c
https://www.digikey.pt/product-detail/en/on-semiconductor/BC559CTA/BC559CTACT-ND/4213839
https://uk.rs-online.com/web/p/bjt-bipolar-transistors/5452484/
