WTT 4x Grayhill Continuous 71 series switches
Potato Cakes
Nashville, TN
A while back I ordered some Grayhill switches and accidentally purchased the continuous version instead of the programmable stop pin version. These are brand new, 1/4" shaft, 12 position, single pole, single deck. I just opened them today as I was starting a project and noticed the discrepancy. Looking to trade for same version 71 series but the stop pin version. Hopefully with someone in the lower 48 states to make things easy.
Paul
    771.3 KB
I have successfully drilled stop pin holes in continuous rotation Grayhills.  I wrapped the switch with tape, unscrewed the brass hwd, pulled the front plate off, and drilled the hole.  The "innards" of the switch were all set up for a pin, just no holes in the front plate.
Bruno2000
After becoming uncomfortably familiar with the inner workings of the Grayhill switch, I managed to get it open and place stop pins inside all four of them and then close them back up without the need for drilling. Thanks for letting me know about the insides being the same as all the other 71 series switches.
Paul
Paul
+1
Bruno2000
