The switching frequency is 400kHz, not 400Hz.Stick a 100uF Cap and a 10mH/10Ohm choke there, after the PCB.
To lower noise on the input side, 3,300uF/100uH/0.1Ohm/3,300uF will isolate the incoming voltage from switching noise.
Thor
Thor
Thanks, I have ordered a couple of suitable chokes. Yesterday, a test with my new tube microphone preamp using an ordinary RC filter yielded positive results. There is certainly still room for improvement, but overall the whole thing was promising.Stick a 100uF Cap and a 10mH/10Ohm choke there, after the PCB.
Among other things, I actually "measured" something around 400Hz, which irritated me. As I said, my approach could be improved and it could also be due to the upstream power supply, possibly interference?This PCB, you are quite sure? And you are sure the bodged up 34063 works nice and stable without subharmonic oscillation?
It's not what I see on the 'scope shot in the back of the pic, BWTFDIK.
As I said, my approach could be improved and it could also be due to the upstream power supply, possibly interference?View attachment 144241
I am trying to understand the function of the small board in detail with this test
Thanks, that helps a lot.
Using a USB-C Brick supplying 20V/5A (100W)
I have seen more music equipment (e.g. controller keyboards) running from USB power these days. Any concern about the very light friction fit of most USB connectors?
It helps to not break your power adapter when you accidentally pick up your phone or laptop when forgetting to unplug
but studio and stage equipment usually needs a more secure power connection.
There are one's with a latch or other lock
I see 2.1mm DC a lot. That is less secure than USB-C
Agreed. Sometimes equipment will have a clip of some kind to hold the cable so that if the power cable gets tugged it just pulls on the clip, not the barrel connector, but still not ideal.
To get anything other than 5V you need a microcontroller to negotiate the handshake, correct?
That makes it a little more difficult for a lot of DIY cases.
Maybe someone makes a turnkey device you can drop in, I haven't researched it yet.
The catchphrase is USB PD Trigger
Thanks, had a short crash course in USB PD today. Looks like a great way to get decent power supplies at commodity prices.
I would jump on this bandwagon, such a great idea. Just finished another power supply for the umpteenth time and am tired of it. Count me in, not sure how I can help but am quite willing to contribute.Even at the risk of repeating myself. I would very much welcome it if this idea becomes reality. I have no idea how I can help, but I hope more people jump on this bandwagon.
Think about how a clever solution could make life easier. You set what you need and take care of the (amp) circuit instead of building a dedicated power supply for the umpteenth time.
That would be great, I think it would really cover a wide range of possible applications.HT : +120V ... +360V @ 200mA ... 70mA
BIAS: -40V ... -120V @ 30mA ... 10mA
P48 : +48V @ 200mA
LT :+6V ... +12V @ 8A ... 4A
AUX: +/- 12...18V @ 0.35A
Noise levels comparable with LM317 etc. 3-Pin regulators and Switching noise LC filtered into the (a few uV) noisefloor.
USB PD now offers really amazing possibilities, the feature would certainly be nice to have, but is not the main focus for me.USB-C PD 100W x 2 (redundant)
I feel like I'm in a fairy tale, these are certainly very attractive features. +1 for the "Blinkemlichten"Special Features:
Multiphase switchers for reduced noise and component stresses
Synchronise all switchers to a clock derived from 12MHz on board Xtal or a 256 X "Superclock" at appx 750kHz
Power on sequencing (e.g. Heater on and stable before HT turns on) and soft start
Power monitoring and interlocks in case of failure, few cute LED's so we have Blinkemlichten.
That's a good question! I'm usually in the all inclusive camp as I really appreciate simplicity. The more I think about it, the more I favor the modular approach here. But maybe you could make two editions, for example one edition for power amps (high power, bias voltage, but no phantom) and a smaller edition for lower power preamps. Difficult decision, probably a modular approach with common sync is the best approach. You only take and pay for what you really need. Space requirements also play a role.This could go two ways...
One Big Bird ... ahhhmmm Big Board with everything on it...
Or
Split into Utility / Input, Tube, P48 and AUX supply boards (4 separate boards)
Each board could also operate by itself.
true.One single board is much less flexible but probably covers 90% of all cases and is pretty idiot proof, but is a biggish project.
also trueMultiple boards are very flexible. And different boards could be developed by different peeps.
That could work, but it would bring even more complexity. In my humble opinion, I would reduce the project to the tube application, which is already complex enough.In terms of flexibility, you could, for arguments sake, use multiple P48 and AUX boards to power a really big Solid State mixer at nearly 200W consumption.
This is indeed often the case, but in this case I think a modular approach would be the better way. YMMV.I just find that peeps usually overestimate the benefit of flexibility and underestimate the benefit of simple Turnkey.
It's completely understandable, we need more supporters. Volunteers please step forward.PS, I will not design this and make it a ready to run project, but if someone does as open sauce project I'll help for free.
