The lowly GC2020 is a compressor that was mainly a piece found in use in live rigs and occasionally the project studio. I had a pair at one point, but now I'm down to one.
I opened it up one day to find some decent capacitors (Rubichon), what appeared to be various ICs and instead of VCAs I found OTAs.
There were also some transistors here and there, most of which I was able to identify via Google but my parts hunt isn't quite complete. I have turned up nada in regards to a schemo, but I would be glad to post pics of the PCB.
Here's the grocery list of stock components that I identified.
NOTE: I haven't cataloged the capacitors or resistors yet, but after some time on the web I identified the ICs, transistors and OTAs
(2) 13600DB/JRC5005, (3) LA6324/4L8, (4) NJM2043SE/JRC5719, T TA75559S DOT 51, C2878 A SJ, A1015 GR51, TB 5 DOT H.
I've been kind of stuck on National Semi Conductor stuff so I kind of stuck with them as I used cross references to find replacement/upgrade parts.
Here's where I wound up:
Replace the 13600DB with Lm13700 or NE5517
Replace the LA6324 with National LM324N.
Replace the NJM2043 with National LM49720.
Replace TA75559S with National LM1458 or National LM8272.
Replace C2878 with Fairchild BC546B
Replace A1015 with Fairchild BC560C
I realize that some of the IC changes would require socket installation.
I figured this mod would be pretty cool if the GC2020 could be cleaned up, especially at the input and output amp stages. If the OTA is adding noise or haziness, then I'd definitely like to see some improvement there if possible.
I'm thinking that I'd love to go for clarity and transparency where possible.
I'd love to hear some thoughts especially on my upgrade choices.
I'll try to find out more from the unit if I can. I'm going to put a call into Yamaha customer support since their service manual for this compressor isn't on the site. They've helped me in the past with my PM700 project.
Peace
Illumination
Peace
Illumination
