Problem not solved, re-occurred again. At the risk of being redundant the problems are as follows: sound will play fine when suddenly it starts getting distorted; if I stop the music the headphone amp has a low hum which is not there when I power the unit on and everything is working fine; only the positive rails are being affected, i.e. they are the only ones whose output is halved - see chart on page 2 - the negative rails stay consistent; when I pan the signal the VU meters do not react accordingly, i.e. if I pan hard left both VU's are still moving in sync (headphones adjust accordingly, VU meters did work normally); heat sinks from power transistors on PSU are extremely hot and now the power transformer heats up too.
I've tried unplugging the channels individually to see if any one channel was the cause of the problem. This is apparently not the case. When I unplug the Monitor 1 channel, Monitor 2 -which has the headphone amp - stops working.
I'm stumped (not that I ever felt like I gained some understanding of the problem) and still find it very strange that only one part of the power supply is being affected. Having said that, the 12 volts powering the headphone IC remains constant.
Any thoughts???
