keefaz
You can experiment some mods on one channel to lower the current, I would remove TR6 and TR7 then link opa604 output (pin 6) to the bipolar cap (BP 47/16) with a jumper
keefaz said:You can experiment some mods on one channel to lower the current, I would remove TR6 and TR7 then link opa604 output (pin 6) to the bipolar cap (BP 47/16) with a jumper
spaceludwig said:abechap024 said:Maybe try increasing the feedback loop capacitor from (27pf, 47pf?, 100pf??) to a higher value.
EDIT: I'm not sure what opamp your talking about, but those compensations do look pretty lean for some modern fast opamps.
The only cap i am seeing in a feedback loop of ic 2 is the 22pF cap in parallel with the 33k. I don't know how changing that value to a higher cap would change anything...
spaceludwig said:Would you know what function those 2 transistors are performing?
abechap024 said:Increasing that cap value lowers the bandwidth the opamp is amplifying, sometimes those caps play a very important role in stability.
abechap024 said:You can think of those transistors as a souped up output stage of the opamp, the have more current drive (maybe thats where the extra current is going) and a lower impedence, example they could dirve an output transformer, while most opamps can't
(edit) Sorry I made a confusion with opamps pinsspaceludwig said:Just to be sure: When I use the original opamp (TA7136P) in place of IC 2 the current draw of the circuit is around 40mA. If I use a newer opamp (opa604, 5534, etc) with all pins EXCEPT output (pin 6) connected it draws the same amount. However, the moment I wire the output it jumps over 100mA for a total of 130+ mA. This is the result of oscillation, correct?
keefaz said:... I don't know, I think I would experiment with unsoldering the transistors at output of IC2 and connect the opamp output to the bipolar cap
abechap024 said:You could do some listening tests...
;D
