I posted this question before but never got confirmation. Trying to determine if R72 is switched out with the eq engaged. The diagram indicates no however logically I would think yes - the reason being with EQ engaged wouldn’t R72 load or otherwise affect the input of of the low frequency EQ since C11 and the low freq. EQ inputs are parallel?
Secondly please confirm R70 is always in the path whether EQ is in or out. I know the HPF needs it but wondering if it affects the EQ out path
Thank you
Thank you
