I finished up my 4-channel 312 build a few days ago. Everything works except the VU buffer circuit, as I need some germanium diodes for the bridges and shielded signal wire from the main boards. I used Fabio's PCB design. Channels A & B are 2520BCs, and C & D are Melcors, both DIY. All the boards were etched by me at home. Cinemags in and out on all four.
I screwed up and ordered relays with the wrong footprint, which explains the yellow jumper wires. I probably should have sucked it up and bought new ones. I also wish I would have ordered a deeper chassis, as it was a tight fit. Oh well. Front panel was laid out in Illustrator and engraved by FPE. No in-fill. I sent them my Par-Metal front panel, but the USPS lost it. I had to use their material.
Oh, and Dort is my last name, which explains the symbol on the front. The logo is based on the old Dort Motor Cars logo from the turn of the 20th century.
