I would try to understand WHY it's better to do things one way or another as opposed to just asking people what method they think is best. The 1646 is a 5K inverting input. Two issues about this:
One issue is that your 10n capacitor is going to make a HPF of over 3KHz. Even your 1u is 32Hz which is actually a little high. Granted, there's not much gain in this part of the circuit so you probably wouldn't hear it but why not just use a larger cap? Even a 4.7u film cap is not terribly expensive. And, yes, you could just ditch the coupling cap entirely. You might need to sanity check the output offset but with the servo caps on the 1646 output, I don't think it would be a problem.
Two second issue is that the noise gain of an inverting stage is higher with higher impedance. So the HPF capacitor looks like higher impedance at low frequencies. So the cap either needs to be large (which means you don't get filtering) or you need to buffer the filter.
Personally, I would do it the way I just did in the schematic I posted a the top of this thread. If you use a high quality audio grade cap in the CFP gain control network, you can implement low cut very effectively. The only issue with doing this would be distortion from the large electrolytic capacitor but I was not able to measure any distortion using a Nichicon UES cap. And the high impedance at low frequencies does not increase noise. And because it limits the gain at low frequencies (as opposed to removing low frequencies later), you can get more signal into the circuit without clipping.
