Something that seems to be important with the Piezo element for plate reverbs is the resonant frequency of the piezo.
There used to be a website www.platereverb.com/ from Jim Cunningham (Echoplate) with some good info on building your own plate. Jim also sold there some parts, like the piezo elements.
the website went down sometime around 2015, here is the page from wayback machine:
https://web.archive.org/web/20150409235759/http://www.platereverb.com/
Here is some notes I have from Jim Cunningham:
"The pickups are piezo elements but it is important to choose one that has it's resonant frequency well outside the audio range. All piezo devices have a screaming resonance so this is very important. Also they must be mounted with a special conducting cement (to avoid ground loops) which we supply with our pickups."
From another source:
"Jim Cunningham also sells some piezo pickups. These pickups just look like the standard piezo transducers that are maybe 20mm in diameter.
They get glued on to the plate with a fast bonding adhesive"
________
I didn't find any source for Piezo elements with the resonant frequency outside the audio range, if someone can find them or have a source please let us know
thank you so much
________
thank you so much
