Your Realiable Partner for Quality PCB-PCB&Turnkey Assembly Service
PCBX
Active member
White Market Member
10.17 Made the board of the QEZ keyboard with PCBX
10.8 Updates
PCBX Rigid-Flex PCB
Industry: Military Industry
PCB Information
Surface Finish: ENIG(Immersion Gold)
Board Size: 59*58mm
PCB Type: Rigid-Flex PCB
Board Type: Single Unit
Soldermask Color: Green
InspectionStandard: IPC2
Layers: 4 Layers
Materia lDetails: Multi-rigid-flex board
Assembly Side: None
9.24 Updates
Just wrapped up another amazing board assembly with the team at PCBX!
Excited to see the innovative designs come to life. Stay tuned for what’s next!
Double Side Assembly PCBX (9.20 Updated)
Industry: 3D Vision Effect Industry
PCBA Capability
PCBA Cleaning
Dispensing Glue
PCB Information
PCBType: FR4
BoardType: Pannel
SurfaceFinish: HASL
SoldermaskColor: Black
InspectionStandard: IPC3
Layers: Unknown
MaterialDetails: FR4
AssemblySide:2
Aluminum Sandwich PCB at PCBX (9.18 Updated)
Industry: LED Lighting
PCB Information
PCBType: Aluminum sandwich panel
BoradSize: 36*90mm
BoardType: Single Unit
SurfaceFinish: Immersion Gold
SoldermaskColor: Green
Layers: 4 Layers
MaterialDetails: High Heat Dissipation
AssemblySide: None
3D Printing Battery Charger PCBA Board (9.16 Updated)
Industry: 3D Printing Battery Charger
PCBA Capability:
One Side SMT
One Side THT
PCBA Cleaning
Plug material shaping and welding
IPC-A-610 IPC Standar 3
PCB Information
PCB Type: FR4
Borad Size:181*95mm
Inspection Standard: IPC2
Layers: 4 Layers
Material Details: FR4-Standard Tg 140
Assembly Side: Two Sides
High-Density Multilayer PCB (9.11)
PCBType: High-Density Multilayer PCB
BoradSize:69*120mm
BoardType:Single Unit
SurfaceFinish:ENIG(Immersion Gold)
Layers:20 Layers
MaterialDetails: High-Density PCB
AssemblySide: None
BoradSize:69*120mm
InspectionStandard: None
Layers:20 Layers
MaterialDetails: High-density multilayer board
AssemblySide: None
Get your own at PCBX- https://www.pcbx.com/?mtm_campaign=AD&mtm_kwd=forum&mtm_source=GDIY
PCBX Campaign for New Users! (9.10)
At PCBX, efficiency meets innovation where the manufacturing of world-class PCB and full-product assembly is both an art and a science.
Established in 2005, we've been at the vanguard of delivering advanced and budget-friendly solutions to the global electronics market.
Trusted by over 10,000 companies in upwards of 120 countries, our clients return time and again for PCB solutions characterized by our nearly perfect satisfaction rate. Every assembly is a testament to our dedication to excellence.
Register for Free Order​
For new users, sign up and your first PCB/PCBA order is free of charge.
Campaign Details​
1. Your first order for 10 PCBs is free.
2. The first order of PCB Assembly for 10 pieces is free, only applicable when ordering PCB or components from PCBX.
Notes: After registering, you will receive two coupons automatically.
Sign up now and order in PCBX for your first free order! 👇
I just gave these guys a try. I will let you know when I receive the PCBs.
ian
Thanks, Ian, we're also looking forward to your review when receive the PCBs. :) Let me know if you need any assistance in the meantime.
Copper Core PCB
Industry: High Power Module
PCB Information
PCBType: pcbx Copper Core PCB
BoradSize:65*17.5mm
SurfaceFinish: Copper Core
Layers:1 Layer
AssemblySide: None
Get your own FREE PCB 👉at PCBX
Free DFM Check​
Along with our PCB Assembly Service, we offer Free PCB File Check or Free DFM (Design for Manufacturability) by checking your PCB design files for any problems that will delay or trouble the manufacturing process. If there are any problems, we will notify you right away by email and work with you to correct the issues and adjust the fabrication schedule of your PCBs as necessary.
Drill Checks​
Signal and Mixed Layer Checks​
Power/Ground Checks​
Solder Mask Checks​
Silkscreen Checks​
Aging Tests in PCBA Production
During the PCBA production process, the aging test is essential for ensuring the reliability and durability of the finished product. This test simulates external conditions like high humidity and elevated temperatures, effectively placing the functional board under stress to observe how it withstands changes in air temperature and other environmental factors.
By undergoing this rigorous testing, manufacturers can identify potential failures before the product reaches the market, leading to higher quality and more dependable electronic devices.
Have any of you experienced issues related to aging tests in your projects? Learn More
Full Turnkey Assembly Prototype Application-Car Industry
What else can you think of any other applications for PCB Assembly?
Designed by Cmatkin, manufactured by PCBX
Full Turnkey Assembly for Electronic Music Equipment
Get Your First PCBA Free at PCBX 🤩
Solution
Eecart technicians ensure that the design meets production requirements before production, and correct errors before production.
Find the most suitable components for users’ products
PCBA assembly
One-stop service
H-Bridge Project with TIP120 TIP125 Transistor
Build H-bridge on breadboard and then design PCB and produce full PCB assembly​
🤝---Designed by Robojax 🤝---Manufactured by PCBX
  • H-Bridge-1: Building H-bridge motor driver on breadboard using TIP120 and TIP125 Darlington transistor
  • H-Bridge-2: Designing PCB and placing the order for PCB of H-bridge using TIP120 and TIP125 Darlington transistor
Get your own at PCBX👉 https://www.pcbx.com/?mtm_campaign=AD&mtm_kwd=forum&mtm_source=GDIY
Capacitor Charging Circuit
Description
Circuit Components:
A 9V battery.
A 200μF electrolytic capacitor
A 330Ω resistor
A 100Ω resistor.
A red LED.
A yellow LED.
A SPST switch
Circuit Description:
Assemble a charging circuit with a 9V battery, a 200μF capacitor, a 330Ω resistor for charging, a 100Ω resistor for LED current limiting, two LEDs (red and yellow) in series, and an SPST switch. Connect the battery's positive terminal to the 330Ω resistor, and then to the capacitor. Attach the capacitor's other terminal to the negative terminal. Link the LEDs in series with the 100Ω resistor between them. The switch connects the LED series to the negative terminal. When the switch closes, the capacitor charges and the LEDs light up.
This circuit uses a switch to control the charging and discharging of the capacitor, with the brightness of the two LEDs indicating the state of charge of the capacitor.
Make your own Simulation Project at PCBX
Free Online Arduino Simulation Project- Arduino-Based Counter with LED on Multiples of Three
👉 Simulate your project at there- https://www.pcbx.com/?mtm_campaign=AD&mtm_kwd=forum&mtm_source=GDIY
Connections:
LCD to Arduino:
RS (Register Select) pin connected to Arduino Digital Pin 12.
E (Enable) pin connected to Arduino Digital Pin 11.
D0-D3 (Data pins) connected to Arduino Digital Pins 5-2 respectively.
D4-D7 (Data pins) connected to Arduino Digital Pins 10-7 respectively.
LED:
Positive leg connected to Arduino Digital Pin 13.
The negative leg is connected through the 220Ω resistor to the Arduino's Ground (GND).
Code Functionality:
Initializes LCD, and sets LED as output. Clears LCD, displays "Counting to 100...". Counts 1-100, displays count, blinks LED for multiples of three, counts blinks. After counting, shows "LED Blinks: X" and halts.
After counting, shows "LED Blinks: X" and halts: Once the count reaches 100, the program stops incrementing and displays the total number of LED blinks on the LCD. The program then halts, and the final message remains on the display.
Project link: https://www.pcbx.com/sim?id=6866cc2e8da3440288b2b2d9dcc7a493&type=share
Key-controlled Seven-segment Digital Timer
Play FREE Online Simulation Online- https://www.pcbx.com/online-simulate?mtm_campaign=ad&mtm_source=gdiy
Simulate your own digital timer at PCBX
Description
To implement this project, we need:
An LED display (a common cathode LED display is used here);
A switch to start timing.
Connect the a-f pins of the LED display to the D2-D8 pins of the UNO, and connect the common cathode of the LED display to the GND of the UNO. Detect the state of the switch through pin A0 of the UNO.
When the switch is pressed, pin A0 of the UNO goes high, and the LED display will start timing from 0. When the count reaches 9, it will reset back to 0.
I ordered a set of PSU boards from them. The quality and price were both great. Shipping took a little long, but that’s true of everything coming from China via ocean these days. I would definitely use them again.
Thank you for your message. Could you please provide your product number? We would like to offer you a coupon in appreciation of your authentic review.
Regarding the shipping methods, there are several options available. Choosing global direct shipping is the most cost-effective, but it may take a bit longer. If prompt delivery is a priority, DHL and FedEx are more suitable options, though they come with a higher cost.
