burdij
Just a guess but, it appears that the Lundahl circuit is attempting to drive the negative terminal of the transformer through the negative feedback path. Ordinarily, the positive input feedback path would attempt to keep the negative terminal of the opamp near zero volts (+- the DC offset). In this case, the negative terminal of the transformer and negative terminal of the opamp appear to be acting in a "current mode" relationship so that when the input voltage rises, the opamp attempts to move the negative terminal of the transformer toward the positive voltage direction. This would result in a net instantaneous voltage across the secondary of the transformer of zero volts, nulling the field within the transformer secondary. From EE class, I vaguely recall that the inductor represents a high impedance to the changing voltage (as opposed to a capacitor, that represents a low impedance to changes in voltage).
The capacitor C does two functions, apparently. The first is to prevent DC from flowing in the secondary. The second is that it serves as a high pass filter with respect to R (some kind of impedance mirror across the opamp is allowing them to interact, perhaps someone can elucidate). A one pole filter of this type has a rolloff of 6db per octave, I think. The reason why the value of R needs to match the DC resistance of the transformer winding is probably because the two resistances form two legs of a wheatstone bridge. When all currents and voltages are in balance, the lowest THD (center of the hysterisis curve) results. The other circuit that was referenced in a later post does not appear to have a similar function to this circuit, in that there are no impedance elements in positive feedback path.
