We have installed the IEC terminal and are working on the power transformer. As of now, the orange and red cables, are going to the CT slot on the PCB board.
1. First question, do we need to have these going into a terminal first of use connector wire? Is this necessary? If we use connector wire, do we need to use a terminal to connect the two together, or can we simply solder the two wires together?
2. We have a blue, brown, grey and purple cable coming out of the transformer. These are heavier gauge wires. We are trying to figure out where they connect to. Keep in mind, we are doing a 120V build. Do these 4 cables attach to the IEC terminal, the Meter switches, or something else? Can you also tell me exactly what part of these terminals they connect to specifically?
