deepmojoman
Member
- Joined
- Jan 7, 2017
- Messages
- 9
- Reaction score
- 0
Hi all. I have decided that I want to adI/O transformers to my Art Pro MPA II. But, there are impediments that I'll need help with:
1. Currently there are no schematics of the MPA II anywhere on the internet, and . . .
2. Tony at Moddefaction says that he feels that if you added an input trafo then that would cause the Variable Impedance function to operate incorrectly since any trafo you added to this circuit would be of a fixed impedance.
As far as impediment #1 goes, thanks to a post on this forum started by KingKorg I was able to get my hands on the schematic for the MPA Digital, dated 2003. I looked inside my MPA II, and I'm confident I'll be able to work with the schematic from '03, as I'm pretty confident that not a lot has changed about the the Variable Impedance circuit.
Which brings us to Impediment #2. I spoke to Dave Garren-owner of Cinemag, and I told him what I was thinking about doing (I'm thinking of the CMMI-5C for the Input trafo, for a nicely charactered sound), and he said some things that I will need some insight on:
1. Replace the 5K dual pot currently controlling the Variable Impedance circuit with a new pot (he suggested somewhere near the value of around 18K) . . .
2. And also to add one resistor apiece to each leg of the pot going to ground, so as to prevent the transformer from shorting out.
He suggested that I do these things once I asked him whether or not simply adding the CMMI-5C (3750 ohms impedance on the secondary) would just simply add that impedance to the maximum 2.7k ohm impedance you get from the Impedance knob. I wasn't quite clear of his answer but he nicely subscribed those two suggestions for my dream circuit.
So this is where I will need some help from you guys:
1. Does anyone out there have any idea of what putting an input trafo right in front of a new pot with a value different from the stock 5K do to the Variable Impedance circuit (like: will it just add it's secondary impedance to whatever impedance is dialed up on with the Impedance pot, or is it a much more complicated process)?
2. Does anybody have any idea what value of pot I should be looking for?
3. Finally, does anybody have any idea of the value I should use for the two resistors that I will include between the pot's negative leg and ground?
I have included the '03 schematic of the input section of the MPA, so that you can know what I'm talking about.
Thanks so much.
Thanks so much.
