granger.frederic
- Joined
- May 22, 2010
- Messages
- 488
MS Vienna said:Tim Campbell said:MSVienna is referring to the fact that the acrylic is cracked in multiple places. It's very likely that the capsule was exposed to alcohol.
Exactly!
or it's just the effect of time and different thermal expansion of the metal (screws , backplates, peripheral ring) and the acrylic ...
the elasticity modulus of the perspex tends to decrease with time , it has also a poor low and high temperature resistance and a poor fatigue resistance
add that all the parts in the CK are mechanically tensioned
after 40 years , with sometimes brutal thermal variation , cracks occurs ...
perhaps less with the "red version" of the CK12 material , Tim could confirm ?
Maybe that's why AKG came to Teflon in the next capsule revision ...
I have a CAD CAM/CNC machine at home , and i often think about milling that part inside a hybrid ceramic block (composite with 80% of ceramic) that has very good mechanical /chemical /electrical properties...
