Looks way better - a bit more treatment and you should be fine. Maybe bringing the monitors closer to the desk so they are closer to you might sort the under-desk issue, but they need to be the correct distance from you. Running a tape measure from your ear to the monitors to ensure you get the same distance as the spacing apart of the monitors for optimum listening position will determine the best location for them.View attachment 119989
this position is speakers 134cm apart and mic is now just before the desk, pretty much where my head would be over the keyboard.
the main change here is i now have 3 panels above my head and ive put a makeshift panel on the floor on the front wall, as below the desk there is a big build up of 120hz, so i could make a few more panels and put them on the front wall, as when i listen this seems to be the culpret.
pretty major change now.
