Bass traps and diffusers
SoundID (full disclosure, I consult and write for Sonarworks) is great to add the final touches to a well designed room and properly integrated speaker setup. SoundID can nail the stereo image by time-aligning the two speakers and correcting small performance differences between the two monitors.
You can’t fix time domain problems with EQ, so any room modes or reflections will not be corrected by SoundID. Have you experimented with the different phase modes of SounID? I find the “mixed” setting to be the most musical. I love SounID on my speakers and headphones but some people feel differently.
Things have come a long way with software like SoundID and it’s so good to be able to reference with correction in and out and sort some room issues.
In the early days back in the ‘80s there were room correction options for studio monitoring, but most were super expensive and out of reach of most private individuals and small studios. There were hardware boxes which involved a complex setup routine and these then stayed in place in your monitor path - bad luck if you had several sets of monitors $$$.
Companies like Genelec also built correction into speakers.
Back in the ‘70s Philips developed the Motional Feedback speaker which had inbuilt bass correction - I was an apprentice with Philips at the time, working as assistant in the design labs division some days a week and these were a new step into the Hi-Fi market by Philips. A lot of the Hi-Fi nuts pooh-poohed the idea saying it wasn’t a “pure” sound. Funnily enough some of the great albums by Pink Floyd were mixed on these - The Wall, The Final Cut and The Division Bell which I’m sure the same Hi-Fi nuts listened to on their systems.
Trinnov have a really nice correction system but it’s expensive compared to the SoundID and does involve hardware purchase and either renting or buying the special 3D reference mic - I recently did a control room setup with this system, going back next week to do alignment with sub in place. This does all facets of room correction however with phase and time corrections incorporated as well as EQ levelling.
Really interesting info - I had no idea correction goes that far back. I’ve worked with many studios, from home studios, to sun states, to Capitol’s 9.1.6 Atmos room, using all kinds of hardware and software offerings. Trinnov, as you mentioned is effective, as is SoundID, and DIRAC. I’m in favor of hardware-based solutions for their simplicity, but lately I’ve been using Ginger Audio’s Sphere control room monitor software that provides for plugins, bass management, level control, and even delay settings for multiple monitor systems. It is a wonderful time for dialing in great sound.
Many companies are beginning to integrate SoundID calibrations into speakers and monitor controllers and HEDD audio provides a range of speaker voicing options including plugging or opening ports and DSP to adjust associated the LF extension, driver time-alignment, and even desk-reflection correction settings.
Genelec and other companies have integrated tuning options and Dutch and Dutch have even found a clever way to minimize SBIR effects.
Just wait for AI to take over speaker tuning… erm…😳
Pretty well a lot of the ideas in correction of speakers and rooms have been around for more than 50 years - I’ve seen some of the best and the worst having been involved in design, build, equipment installation, wiring and commissioning of well over 30 studios (plus countless home studio setups when I was managing a hi-tech audio and keyboard store). Unfortunately some people think if you throw egg cartons or money at a wall it’ll fix it - either that or forget the wall and fix it in the box. If a room has issues it’s best to correct these as much as possible - then all you need to compensate for is your DAW Interface/Monitor setup.
Some nasty sounding areas in studios have often turned out to be very useful. I was helping build a studio in 1977 and there was a problem with sound ringing from a steel stair beam with hardwood stairs feeding into the live room even though the under-stair area was behind a wall with a door acces for storage. So I fit heavy plasterboard double layered under the stair beam to kill the ringing and seal it off and added isolation to the door Turned out this tiny wedge 12 foot tall at the big end was e perfect reverb or delay with a speaker at the thin end of the wedge and several mics spaced along the length. We also used it to re-record or double snares, record guitar amps etc. We only had the EMT plate and one other reverb then.
In another studio I built I had enclosed the outdoor balcony with soundproof floor over the decking, walls and ceiling and vacuum double glazed windows and doors and added a small bathroom - we called the whole new area a “lounge” so as not to exceed the 100sqM studio area allowed for Cottage industry - over 100 sqM you paid commercial rates on the property at 4 times the cost (big money on 42 acres). Turns out the shower room was perfect for vocals - no reverb needed, or if the door left open a natural reverb for the lounge live room.
Built a reverb unit from a 450mm diameter concrete pipe, speaker at one end and a 57 on a pulley/wire to change reverb time
To my mind if I can’t really hear any difference between soundID being on or off that tells me my room is pretty close to where it needs to be.
I can still hear that there are bottom end differences but it’s very small differences.
I did boost my bottom end on my Adam a7x so might put them back to normal and retest and listen.
But ill do that once ive built a fee more traps and put them on the bottom of the front wall.
Right on! No room is perfect- especially small-ish rooms, but you’re very close and should be super-stoked to work in the room! My personal room has a ring at 40-ish, but the room sounds so good to me that I don’t feel like it changes my decisions and my clients are happy with my work. I always check mixes/masters on headphones vs speakers for many reasons, low end being one of them.
I suppose the next question would be what is the best way to test the drum room now?
Obviously I’m not going to be listening to monitors in there I’m just going to be recording drums, guitars and possibly vocals.
Setup one monitor in there and test with monitor in centre of room or by each wall?
Or just take several measurements where each drum/cab/mic will be?
Measurements don’t matter for the live room. You have to just set up and try it. You could use a speaker on a stool to simulate a vocalist. Play acapella vocals or acoustic guitar through the speaker at a performance volume and mic the speaker. Try it in a few locations and listen to how different parts of the room sound.
Drums are a different story, but basically you’ll have to set up and play in the room. You could set up just kick and snare and move the kit around till you find what sounds good in the room. Even without testing with mics, if the drums sound good to the drummer, they should record well.
I don’t know anyone who measures anything except maybe RT in a live room. The rest is taste and best measured by ear. Diffusers, polycylindrical reflectors, space couplers, and standard absorbers are all effective but there are no real rules.
Avoid “reflection filter” type devices that go around mics - they make any mic sound awful.
It’s all about what the room is going to sound like to the mics used to record a drum kit. You need to ensure you control the top end really well in a room like this and because it’s square you’re going to have corner to corner to corner issues at around 114Hz and 156Hz from walls and ceiling laterally and vertically plus then the diagonals at 72Hz, 81Hz and 92Hz approx. You want the room to sound natural and not ring too much - overtreatment will kill a live room. A quick test is to set up a kit then hit each drum and cymbal, stopping them immediately and listening to the post-hit sound of the room. If a kit sounds good in a room it should sound good to the mics.
The kit sounds pretty good in there at the moment just wondered whether there was a good way of analysing the room to get better results?
It needs redecorating so I’ll empty and paint then go from there
Same applies to acoustic guitar and vocals - if they sound good to the ear the mic will like
Ok so if I’m going to treat the 3x3m room probably just some corner traps and a couple on the ceiling over the kit?
If treating walls maybe only one of any two opposed faces is needed. Ceiling over the kit yes. If the kit’s in a corner you might treat the two walls directly behind the drummer from the corner outwards from the floor up to above mic height.
To analyse just set up a kit, mic it up and record it going around the kit with time spaced hits on each element of the kit - like sound-checking drums for a live gig - then look and listen for any unnatural peaks on the recording that equate to room dimension generated frequencies. These will tend to ring on after the drum hit for each drum.
This waterfall looks very good- even the 80 Hz area is below 200 ms I imagine the room is very comfortable to mix in. You may have found a resonance between your desk and the front wall at 120 Hz that any thick absorber would mitigate. Excellent results.
The waterfall looks good, but what about the spectrogram. I had a similar situation where the waterfall looked good. But the spectrogram was showing a lot of energies in the low mids. My first mixes in that room I ended up scooping way to much low mids. I’m curious to know your thoughts on this.
as space is at a premium in the drum room im thinking i'll build 4 x 50cm x 100cm x 10cm traps with the left over 30kg/m3 rockwool for the corners, two in each corner, floor to ceiling.
i'll then build another two for the ceiling over the kit which i sit against the back wall and face the main door, with the kit pretty much in the middle of the room.
the other door is on the left wall along with the window which i could put another panel over as this might cause some reflections right?
the pink objects are the panels to be clear
