I am wondering, why people still spend € 800,-- for a Drawmer DL241 when you can buy a used Behringer MDX2000 for EUR 30,--. Simply because the Behringer MDX2000 is an exact clone of the Drawmer DL241. (The MDX2100 is slightly different).Hi xefe,
awesome that there are still people interested in modding the Composers!
The Behringer BE2000 in fact IS a SSM2120 - only with Behringer printing on it. (The VCA´s are not used).Gertius said:I have 7 mdx2000s and 1 mdx2100. My mdx2000s come in three versions, one with the daughterboard and 4558 opamps (I guess very late ones), one with all BE027/37 and BE2000 (guess the regular, middle-of-life ones) and one with all those plus the four caps fitted like shown in my previous post (I guess earlier ones that had more budet for parts heh).
All of them have dbx1252. I did not come across an SSM2120 like henk hinted at.
xefe said:The 2100 does not have that reserved space
analogguru said:BTW, could you make some pictures of the daughterboard ?
analogguru said:The Behringer BE2000 in fact IS a SSM2120 - only with Behringer printing on it. (The VCA´s are not used).
Please do so. It would be of some help.Gertius said:analogguru said:BTW, could you make some pictures of the daughterboard ?
As Rossi wrote before, it is not possible to take out the daughterboard without possibly causing some damage.
I could make pictures of the lower side (which is pointing up) and reference the ICs. But I´m not sure how much help that is because you couldn´t say if there are any connections on the top side as well.
analogguru said:I am wondering, why people still spend € 800,-- for a Drawmer DL241 when you can buy a used Behringer MDX2000 for EUR 30,--. Simply because the Behringer MDX2000 is an exact clone of the Drawmer DL241. (The MDX2100 is slightly different).
analogguru
Gertius said:So Rossi, do you still have your composers? Are you still using them?
henk, are you also still hanging around here? I also enjoyed reading your posts quite a bit. Too bad the pics of your mod are not accessible anymore...
Christian
Rossi said:I think good software (e.g. UAD stuff) is superior to anything Behringer ever produced. They were useful, when I recorded and mixed analog, but there's really no place for entry level processors in a digital environment.
Rossi said:Analog recording certainly is a different work style, but I've adapted to the digital world. It has become essential for me to be able to switch between several projects. As you may or may not know, I'm a major contributor for Sound & Recording Magazine, Germany. So I'm constantly switching between various test scenarios and my own projects.
Also, it's not just about analog vs. digital in absolute terms. Basically you have a certain budget, which you can invest either way. I enjoy having really good front end and monitoring, but past the recording stage I rarely leave the digital realm.
Yes, there is the beauty of real faders and knobs, but on the other hand I don't like the user interfaces of most inexpensive boxes. It is easy to dial in the right kind and amount of compression on an 1176 or LA2A, but much less so on something like a Behringer Composer. So it's really 2 virtual knobs on a classic compressor emulation (e.g. UAD) vs. 11 hardware knobs on an inexpensive VCA-Compressor.
But as always, your milage may vary. Just one thing, though: Don't get caught up in having compression on each channel. In the old days nobody mixed that way. Use less compression and ride the faders instead. It's work, but it's also fun (much more so than writing automation in a DAW).
henk said:Nice to see people still busy with the old nice stuff.........................
After this B* did not build that quality anymore...............
