Thank you henk...
no. my trafo isn't boxed, should be no problem...
Am i actually the only one who doesn't dislike but really *hates* double sided B*ringer pcb for obvious reasons???
(Not enough to fight with the behringer rack unit case disassembling...it comes worse afterwards...)
I managed to burn my fingers twice and can't go on tonight because it would be too loud to cut this bloody cheap opamps right from the board with my dremel :twisted: ...
...not to mention i lost a solderpad (that wasnt even connected... :evil: )
I wonder if anyone else does, what i do, if i loose my patience (drilling the holes out instead of desoldering...did this sometimes in the past without any problems...)
the 4580D's are out...oops, Uli, BE027 should have been in there, at least the letters on the pcb makes me believing this (according to Dipl.-Ing. Uli: "unique and vastly improved operational amplifiers"...)
OK, cynic hate mode off...
Yes i want the full mod.
I wonder, henk, if the BA14741 and BA10234 wouldn't get too hot with 18V, if i only change the opamps in the vca line...?
Another task would be recapping the bad electrolytes. These are, like mostly in Uli b's gear, the cheap jamicon and similar caps (brands usually on the blacklist of known-to fail-and-very-bad computer mainboard caps)...
If the unit sounds as good as you say, it would even be a good idea to change 22pF's to silver mica and for shure to replace all 100n's with film.
I just have to figure out tomorrow how to substitute 7818/7918 with 317/337...all i have here at the moment and surely a bit quieter...
Kind regards
