Tim
The supply is now zener regulated to 230VDC. The real sony runs about there. The 200VDC should work. A person might want to adjust the voltage to the capsule via the "top" resistor and maybe the cathode resistor. You will want more than 1.1VDC at the cathode.
There is a real sony schematic with voltages in this thread.
The microphone and PS have changed from the early posts. Now the microphone has a B2 pro capsule and mount cardiod only now. The power supply is going to change a little and a pattern control might be added. If I add the pattern control I will add a switch to drop the rear skin in cardiod pattern.
I would like to find heatpipe so I could make a copper sleeve to transfer the heat outside of microphone body The heat of the tube causes outgassing in the glass, this can lead to more noise.
FWIW I built this microphone more to find out why the real C800G is considered to be a GOOD microphone. Not wanting to spend the thousands of dollars for one I built something like it. I learned alot. Would I build this again I don't know I am not sure if the 6AU6 tube is the best at the operating points of this circuit. FWIW my ears seem to hear lesss noise with NO grid to ground R?
Maybe a EF86 based circuit at 230VDC B+ a 100k plate resistor and a cathode resistor giving about 1.5 VDC at the cathode. Instead of the neumann G3 to ground, G3,G2 and the plate connected together like the sony.
So much to do and learn
