ForthMonkey
Boards arrived!
cromwell said:I´m very interested to hear how the first PCBs are and if you could make the pre work.
If it´s successful I´m going to build a four channel box. I like the choice of all the options you implemented!
I thought about mounting the PCBs horizontal in a chassis, but loaded with two transformers it might be too heavy as it´s "just" mounted via the gain pot and the DI input. What do you think?
Maybe you consider two holes on the opposite pcb side of the frontpanel, for using standoffs?
cheers
Eric
cromwell said:Sounds cool!!!
What kind of DOA where you using?
Did you use a trim pot or stepped attenuator?
Btw: For the stepped attanuator option, what kind of switch did you have in mind, Lorlin 1 x 12 or something else?
Sure it doesn´t matter for wiring to the board, but maybe there is a switch that fits to the pcb without wiring?
Where did you order your boards, do you sell them as well?
Eric
I used UREI MOD1 DOA and simple pot.
I used Grayhill(Adjustable stop.11 position) for design.With pushbutton switches it's hard to use Lorlin.Cause there is no room for Lorlin.But if you wire all of them (toggle switches,di input jack and gain switch),you can use Lorlin.Grahill switch about $18 at CAPI.I will use switches with my other builds.But for now first two build with pot.And it's hard to find 22KC pot.Only found 25KC at Mammothelectronics.
I designed my own self.Now i have 8 boards to sell.But not tried mic input yet.Cause i'm waiting for switches.Then i will sell.
And boards are small.100x100mm.Easy to convert 500 series with adapter board.
cromwell said:I used UREI MOD1 DOA and simple pot.
Yep you are right the greyhill makes sense, didn´t come into my mind;-)
Have you already calculated the stepped resistors, just interested in what you are going for.
I´m interested in four boards depending on how much they will cost.
Eric
Yes,i have calculated resistors.I will add to first post.
€45 for 4 boards including shipping.
cromwell said:I just checked the Greyhill footprint.
Correct me if I´m wrong, but I think it will not fit perfectly.
There is a plastic bar that holds the 12 pins, this bar would sit directly on the pcb when the switch is seated.
I think there isn´t enough space between the switch plastic bar and the RG1 - RG3 resistors.
Or those resitors have to me mounted from the bottom side.
And there are two other pins in front of the 12 pin bar, were I think the holes/contacts are missing.
But maybe I´m to dumb to understand;-)
Here is the Greyhill spec sheet:
http://www.grayhill.com/assets/1/7/Rotary_71.pdf
Eric
ForthMonkey said:The most important thing about this design that you have to solder some components to bottom side.Gain switch and frontend's resistors must be placed to bottom side.Then Grayhill switch will fit as it should be.
DjaiTeam said:Hi Forthmonkey,
Would this project be somehow be able to adapt to the 51x size so would be easy to supply the powerside.
Best Regards,
Iwan
iprovlek said:Here is potentiometer for this preamp!
http://eu.mouser.com/Search/Refine.aspx?Keyword=2-51can-d20-g17
Cheers!!!
