Conn Strobe Tuner
CJ
GDIY Supporter
California
some guitar techs still like this tuner,
kind of a classic circuit, like a GenRad inductance bridge, ahead of its time, so still usable after time passes it buy,
looks like somebody left a can of Starkist Tuna inside here,  probably a roadie for the Allman Bros or somebody,
labor intensive construction, kind of like a Blaupunkt car stereo, ever seen the indise of one of those? sheesh.  :eek:
power switches lead a tough life, mechanical and electrical stress, over and over again,
this sw is mounted on a wafer switch, don't wanna hassle getting a new one and spending all day wiring it up,
so we just jumper the sw and put it on a power strip, case dismissed....
Wow, I have one of these.  Whenever I need to set guitar harmonics, I use the Conn for the precise locations.  It's easy to see on the strobe  light.  Much quicker than my roland tuner.
cool info on the Conn stuff hear>
http://www.mts.net/~smythe/st-11.htm
Forum here>
http://www.petersontuners.com/iforum/lofiversion/index.php?f9.html
hard to read schemo>
> hard to read schemo
There's a less-grey but still JPEGed version in one of your links.
Top-left must be a master oscillator.
By the connections to the C...B 12-way switch, the dividers and diode matrix must form a top-octave generator (never seen this type).
Top-right is a very funky power amplifier and 2-phase motor for the rotor (tuna can).
Signal In is in the middle and gets a basic 3-transistor amplifier.
Bottom right are the Neons, and their amplifier, which I guess can be switched to the boosted Sig In.
I think the extra junk to the right of the Sig In booster is an octave divider for the "+2" function. The highest notes use the narrowest stripes and they are just hard to read. "+2" transposes the notes in bands 7 8 to band 5 6, where the stripes are wider.
Bottom center is a thing called a "transformer", which is too tricky and complicated for present company.
There may be a tap off this mysterious "transformer" which feeds 60/120Hz to the neons for calibration. (Do you trust your local Hydro to be more accurate than your conductor's pitch-pipe? Maybe today. Long ago line frequency wandered hour to hour, they just got the right Cycles Per Day so electric clocks didn't drift.)
