SonicSonar
Member
- Joined
- Jan 12, 2012
- Messages
- 20
chipss36 said:Built champs, ax84, just did not do it for me , dig in on the low strings and
It distorts, if I could do it again knowing what I know now , the tweed deluxe would be the
Best starting point, many great kits for it , not a whole lot more to it than a champ, and useful tones
Still have my deluxe , and still dig it, my champ and the ax84 all sold off long ago.
Agreed, build something you will like.
letterbeacon, that is a very clean build you have there. But carbon resistors?
Warning! My build is not clean by any standard.
I have no face plate to work with. Only a Hammond chassis with drilled holes in it. That is why it looks like it does; total amateur.
My first amp build is from http://londonpower.com/ <-- Everyone should at least check the site out.
I did a 3 channel pre-amp. That contains. LP-PRE, Z-PRE, LINE, BFX.
This pic is not correct. I cleaned up the "wires all over the place" a bit.
understand that is just the pre-amp and it was 3 channels. One could go the really simple route.
Here is a pic of 1 channel and PSU( Power supply) pre-amp. This one was too easy. But sounds great!
It is the S-PRE.
Now to the power amp side of things.
Again, very messy. Pic is not up to date.
Still working on face plate. But it works.
I just wanted to throw this out there. If you have an amp that you really like, I suggest get Power Scaling http://www.londonpower.com/power-scaling
