There are also quite in-expensive analog active crossovers - I mean ~70usd range. Installation or car types even.
In my current 'hifi' speaker build, I'm using one such to find my crossover frequencies. I can then work on some fixed crossover network for inclusion inside the cabs.
Or not! The active crossovers are pretty good to use if you have the multi-amp setup
2way or 3way mono or stereo and with a sub split as well - makes for some very interesting experimenting with speaker and room setups.
These current hifi speakers are going to be interesting
- Sansui 12" alnico woofsters circa late 60s - virtually nos from tube-based gear. These are high sensitivity and quite 'dry', using paper cones. NO poly-whatever cones here!
- Fostex 5" full range, current issue, as a 'mid and little hi-freq' driver. I don't like extended hi-freqs, so I need to dial down the fostex top end to suit.
So, a pair of two-way boxes way boxes, external active 3way stereo, analog crossover with optional sub split
I am still finding I prefer tube amps for hifi, but that's no problem even with multi-amping - my diy tube amps are beginning to pile up all over the place.
I even scored a pair of the Sansui cabinet grills - the intricate wooden trellis types. Awesome ebay find, and continuing this particular styling theme is great - my other speakers are Sansui sp9000 '70s 12" 3way, and a truly wonderful pair of little Realistic 8" 2ways. All with wonderful wooden grills and in virtual nos condition.
I find listening to modern, high power handling speakers with poly woofers not as lifelike as the lower-power rated paper cones.
Excepting my Tannoy 8" concentrics, which sound really good with a proper strong power amp as a studio monitor setup.
Good luck with your build! And if you haven't already, get the free software app 'Room EQ Wizard (REW)' and, like me, try to learn how to use it with a mic for tuning and test measurements!
I have yet to get useful measurements of speaker response tho' - there's a lot of technique in the setup of the speaker-under- test and placement of measurement mic to avoid reflections and such. All good stuff however, and a question of practice
