Matthew Jacobs said:
I'm just thinking, wouldn't "take 100" be much lower quality than "take 1"?
Technically speaking, it all depends... If these 100 takes are done in a sequence that happens to be on a single run of tape, these recordings will be scattered on the tape and each one should be as fresh as can be. Now, since tape is gonna be used several times, it will deteriorate somewhat, but in fact much less than if the punch-ins were done on tape, all at the same place.
One would have to change tape
yes, probably after it has been run 50 or 100 times, depending on the operators thoroughness (and budget)
or change track to preserve quality right.
Tracks don't deteriorate by being recorded or erased. It's only the mechanical wear that matters.
This has to be done manually right? I was just wondering if the CLASP can do this automatically as it was stated that it is Random Access.
My understanding is that they use the term Random Access as in RAM, which the tape recorder is in this configuration. Access is random in the sense that the system does not need to adress a specific location on tape to achieve its functionality.
So I was just wondering if it was that clever or would you still have to keep a eye on it and manually change recording path or tracks.
I reckon the only important thing to keep an eye on is that the tape is rolling. That's why the EOT warning is there.
Or are high grade machine so good, that the tape still sound good after 100 recordings --> erasing --> re-recording?
There would be some tape wear, regardless of it being recorded and erased; a good tape should not present any significant sound degradation afetr 100 passes. Think of it, in the last century, when engineers mixed from tape, they had to play the same sections dozens and dozens of times (with the help of Autolocator) in order to achieve whatever level of perfection they had chosen to adhere.
(like I said my only experience is a Fostex R8 and it sure as hell wouldn't sound good after 5 takes let alone 100 takes...)
Which is not normal. Many people have accepted this as an inevitable flaw of cost-effective tape machines such as Tascam and Fostex, but these machines need to be maintained, in particular the mechanical part of them, guides, tape-rollers, bearings, heads. Most of these machines are now more than 10 years old and have never seen the shadow of a maintenance engineer.
You would be surprised how well an R8 behaves when properly pampered.
