shot
Yeah! We wanna play too!
;D
;D
shot said:I saw on your blog that you did 2520 DOA on a single sided board.
Are you willing to share your layout for self-etchers?
etheory said:This isn't going to be a modular.
I'm building it in a modular fashion only for testing.
The final result will be a single PCB for the analog portion of a whole voice, and another separate one for the digital control board, so you can control every single parameter digitally with 16-bit resolution.
The designs are a custom blend between all sorts of different places.
The RingMod is totally custom but loosely inspired by the Roland SH-5
The VCO is based on the Moog Source but with a whole bunch of mods thrown in, and a more reliable and advanced core, with saw/pwm/triangle and sub outputs simultaneously, along with frequency modulation, amplitude modulation and cross-mod capabilities with hard sync and note-on phase-reset capabilities.
The Filter is completely custom but the broad topology is largely based on the SEM (multi-mode VCF).
The LFO is like nothing I've ever seen before, but is a triangle-core VCO with square output also and phase reset.
The VCA is just a simple SSM2164 x 3, hence 12 channels per VCO pair.
The VCADSR was largely my modifications and simplifications to the OldCrow crOwBX synth ADSR (mine can have much faster Moog-like attack times), which was based in turn on the VCADSR of Jurgen Haible.
Everything has been heavily modified from the original source, and very very heavily simulated.
But nothing built for real. So now it's coming time to build up all of these circuits and see if they actually work as they should, which is needless to say ridiculously exciting.
kooma said:NICE!!!
Are you making more of those final pcb's?
JoshuaUnitt said:Hi etheory,
Just wanted to share my enthusiasm for your upcoming PCBs/kits. With your permission I'd be more than happy to link to them in the DIYRecordingEquipment.com directory when they're finished and available to the public
JoshuaUnitt said:I'm especially intrigued to see your take on the 2510. It seems like an interesting undertaking and the DIY world has more or less neglected the 2510 in its original state (perhaps because of its original operating voltage and pinout?).
JoshuaUnitt said:As far as I've been able to tell, API has used it in some console modules as a balanced receiver (in the place of an input xformer), is that correct?
etheory said:The e274 is still happening!
-shit.etheory said:Sorry...
L´Andratté said:Man, I´m so looking forward to that one.
L´Andratté said:I had the original and loved it, but sold it, because I rather want to mod it
and feel immoral to solder around inside such a museum piece!
L´Andratté said:To put that into perspective, I have to say I´m really stunned by your energy and productivity,
(or the part of it on display here). And anticipation is half the pleasure...
