Dr Gris said:It looks to me as that could be done in a 1RU case, or no?
By design, yes - but it has not been verified in real life conditions
Gustav
Still want to know it.For myself I'm nearly a 100% sure that it was the issue,and a signal will have passed up the mentioned r27,just a few passive parts in the chain.Gustav said:My mailbox is the same. I have begun to assume that no answer = problem fixed
Gustav
O.K.,good to hear!Rocinante said:Ahhh!!! Yes no jumpers. Sorry I run a bar/restaurant so my weekends (especially summer) are... well they are spent there 24/7 unfortunately. So I was able to see what Gustav had responded just before going to work (I can't tell you how frustrating that was) and then dropped my head in confusion cause it seemed I should know this but I am afraid i don't. I have no idea what you mean by jumpers and so no I never installed them.
kante1603 said:O.K.,good to hear!Rocinante said:Ahhh!!! Yes no jumpers. Sorry I run a bar/restaurant so my weekends (especially summer) are... well they are spent there 24/7 unfortunately. So I was able to see what Gustav had responded just before going to work (I can't tell you how frustrating that was) and then dropped my head in confusion cause it seemed I should know this but I am afraid i don't. I have no idea what you mean by jumpers and so no I never installed them.
For jumpers just use leftover legs from diodes or capacitors or whatever you prefer,it's just a conducting bridge over the corresponding tabs.
Check the transistor orientations for a hopefully final time,fire it up and measure the beforementioned control points.Let us know then please.
Good luck,
Udo.
Gustav said:kante1603 said:Hi Gustav,
it seems that the jumpers aren't soldered it in your assembly guide,at least I can't see them.
Maybe he followed the build giude pics a tad "too precise....."? ;D
Udo.
Yep, maybe I thought it would be obvious, which of course, it isn't.. Ill get it added to the guide, when I have some time to do the file rendering/Change the file on the server etc.
And it would still be great to know if this is the actual problem
Gustav
Orchid0 said:Gustav said:kante1603 said:Hi Gustav,
Udo.
Gustav
Sorry just for clarity your talking about the two beside the lundahl output transformer.? -10 and +30? I thought it was weird those were left blank, but I too copied the guide too closely
Also, is it going to be a critical thing if the mains in my house are a little high? Pending on the last couple days I've been testing this project the secondary of my toroid read 28-30.5v ac. Is this terrible for any of my psu components? I know for the gssl it made my rectifiers run a little hot... I just added larger heat sinks...
Do bd139 and bd140 need to be bolted to the chasis or is it not mandatory?
Thanks in advance.
Rocinante said:I do have one little problem though. I can't for the life of me figure out where to tap for the 5v i need to power the vu meter led's
p0ulp said:it's really hard (I didn't try to be too brutal) to push the pins through the PCB, I think I all have to cut some part of the pins anyway.
p0ulp said:Also I don't feel confortable with those small toggle switch if you have any suggestion for a bigger one that would still mount to the pcb ?
kustohm said:Hi,
Yes! What kind of switches please? SPDT DPDT... ON/ON, ON/OFF?
A ref for the round diode bridge?
miszt said:got a pair of the Phat Phet boards (they look great, very nice layout, thanks Gustav!) I'm hoping to build a stereo unit - which components do I need to match and how closely, for the best stereo image possible?
miszt said:also has anyone done any resistor charts for switched versions?
miszt said:lastly, should i build them in separate boxes to avoid interference, or will they work fine in a single 2 or 3U box?
