A transformer is AC voltage.castaeplacpa said:here is my problem: the secondary of the transfomer is only providing +4,75V and + 1,5V. far from the 30V.
measured in respect to the transformers other winding end? IE between red/yellow, between green/blue or between green/red with yellow+blue joined together ? (you measure AC voltage between the winding ends, not in reference to whatever ground,...)the primary wires are the two black ones, and the secondary are a green one, a red one, and a yellow one and a blue one stripped together. and i got these values directly from the wires of the secondaries..
castaeplacpa said:problem solved, in a way, but i have 45V instead of 30.and a resistor of the PSU board apparently didn't like it, she said goodbye with little smoke.
yes i followed what's labelled on the transformer, but a wire was cutted, and well hidden..
i keep looking for mistakes.
thanks
castaeplacpa said:yes a wire (the blue one) was cut inside his insulated coat. i don't know if my english is right..
anyway, i have 45V AC direcltly from the secondary of the transformer (from green and red wire, center tap with blue and yellow wires. )
i have -10V DC and + 30 DC on the output of the PSU which is ok.
for the moment i don't know why this resistor fried, i don't think it's related to the tension but there is no short-circuit on the board, so i keep troubleshooting.
the fried resistor is the one of the two located aside the diode bridge, the closest to the 4 caps.
thanks for the concern
Maybe your multimeters battery is low, giving maybe false readouts.castaeplacpa said:and there is a picture of what i get.
the two secondaries are labelled as : sek I : 30V rt-ge sek II : 30V bl-gn.
so.
from red to yellow i get 38V AC
from blue to green i get 38V AC
with yellow and blue stripped together and measured from red to green i also get 38V AC. (picture) instead of "around" 60V AC..
so.
castaeplacpa said:here is a picture if it could help.
Harpo said:@Gustav, your PM box is full ...
castaeplacpa said:thank you
i fixed it, it was a bad contact..
now the psu works fine.
the unit is not compressing, only the dry signal with hum, increasing with the dirt pot.
so i'll stop bothering you and check my groung wiring, and study the schematic carefully.
i have a few diy projects working fine, so i'll check if i have done mistakes (grounding, wiring..)
thank you again
castaeplacpa said:the DC after regulation: -11,2 V DC and + 25 VDC (?). i'll check before regulation in a moment.
castaeplacpa said:the wires of the secondaries are so thin that the blue one was cutted again. so even if i thought it was stripped with the yellow one, it was not the case.
yes i find the voltages a bit high, i'm closer to 71 VAC than 60 VAC.
the regulators are not that hot, i keep survey that.
i fixed my hum trouble, got a clean signal and compression as expected, but i'll check all the voltages.
thank you
