castaeplacpa
Member
- Joined
- Jan 31, 2014
- Messages
- 13
hi
i just finished a fet grinder and i have a silly question: what's the fuse value?
thanks!
thanks!
dipfrik said:…right from my workbench
I definitely found some sweet spots without calibrating the unit right after the first few minutes or in different words: "this board is kick ass"
Any hints for the calibration?
Thanks, Sven
PS: the "DIRT-POT" i a must on the front panel *g
dipfrik said:Any hints for the calibration?
dipfrik said:Ok, now the problems are starting
I connected a Sifam VU Meter with no signal (all pots are ccw) and the moment i put the Meter-Switch to show gain reduction the needle cranked up immediately to full scale.
MTR-Track and MTR-Zero has no effect.
hmmm…any idea? Wrong meter? Do i need a special meter?
Thanks, Sven
redcheekmusic said:I have a question about the bypass and meter switches. And I am sure this is could be read from the schematic or something, but I am not wise enough to do so.
So the question is:
Is the toggle switch up or down for bypass, and which of the meter settings are up (and which is down)? I need to know this for the front panel design...
Thanks in advance.
I wouldn't know where to start trouble shooting going by this sparse info. Compression working? Q-bias calibrated? Just the meter circuit acting weird?
Cranked to full scale, what does that mean?
Standard VU meter should work...
Gustav
It depends on which way you turn the board, so its probably easiest to just test your desired set-up in practice.
Gustav
So with your VU meter in GR mode setting trim the 'zero adjust' trimmer that the needle points to 0 VU with no audio input signal applied.dipfrik said:I mean the meter needle get hard full swing to the right and stays there.
I use a "SIFAM AUDIO LEVEL METER AL29WF".
What do you mean with "Standard VU meter"
Harpo said:So with your VU meter in GR mode setting trim the 'zero adjust' trimmer that the needle points to 0 VU with no audio input signal applied.dipfrik said:I mean the meter needle get hard full swing to the right and stays there.
With input signal applied and the unit compressing, trim the 'tracking' trimmer for showing the same amount of dB gain reduction (needle now moving from 0 VU to the left side of your Sifam AL29 VU meter) as your audio level is compressed/reduced. As both trimmers are a little interacting, you'll have to repeat this procedure some time.
dipfrik said:Harpo said:So with your VU meter in GR mode setting trim the 'zero adjust' trimmer that the needle points to 0 VU with no audio input signal applied.dipfrik said:I mean the meter needle get hard full swing to the right and stays there.
So that's exactly my problem. If no signal is applied and i switch meter to GR mode, the needle jumps very hard (i mean really hard ) full to the right immediately.
The 'zero adjust' trimmer has no effect at all. I checked the meter on a D-AOC and D-LA2A and its fine. If i switch to output mode the needle goes full left (no signal applied).
I checked also a few other vu meter that i have here and it's on all the same behaviour.
The ratio board is really not that complicated to make big mistakes
Thanks, Sven
