seavote
http://www.prowessamplifiers.com/schematics/fender/princeton_aa964_schem.pdf
http://deeringamps.com/workbench/princeton_layout.html
hi ,im a novice i know a bit but im confused about where to go to get my brothers blackface princeton up and running again.about 18 -20 years ago he had an overdrive switch put in and the rectifier tube bypassed with a bridge diode. the tech installed a monster transformer for the B+ voltage and added another transformer. from what i could make out the transformer secondaries put out 34V. he used this to supply the 4 tube heaters (in series??) and to make a -34V regulated for bias supply to the power tubes. no, i dont know why he thought it was a good idea,maybe he was experimenting and threw in whatever transformers he had on hand. after about a month the amp burst into flames and was ressurected about a month ago for me to repair. we decided to go back to stock. i removed the 2 transformers, got whatever components i needed to put the -34V bias supply back to stock,replaced all electrolytics,replaced two burned out resistors,replaced the power tubes and had the 12ax7,7025 and GZ34 tested.all tested good.i checked for continuity where ever i could through out the entire circuit.
i had a transformer from a dynaco sca35. it had the correct hi voltage secondary and a 6.3V heater supply but no 5V supply for the rectifier tube heater. i got around this by using a bridge rectifier(rebuilt,not the one the "mod" tech did) when i plugged the amp in i got the correct AC Voltages up until the exit from the transformer. after that low MVs on the B+ and a high voltage( i think about 40Vs but dont recall)on the heater supply(with no tubes).
so i went and bought a hammond 290ax. a direct replacement transformer. took out the bridge rectifier, installed the rectifier tube. powered the amp up and now im getting only voltages in the mv range from all 3 legs of the secondary.
on the layout (see link above)diagram the transformer has a green and yellow ground wire that the hammond transformer does not. the red and yellow ground wire from the transformer is grounded on one of the transformer screws coming through the amp chasis.
another note: i replaced the filter caps canister with 4 individual caps, twisted there negative legs together and grounded them at the same screw.
im not sure where to go from here. hopefully im missing something very obvious(again im a novice)
id find it hard to believe the new transformer is at fault. is there a way to test it with no load without burning it out??
please any suggestions are appreciated.
thanks and sorry for rambling,i just wanted to give you forum members as much info as possible. i'll shut up now and hopefully one of you can take it from here.
