JLM Go between kits , how to modify for impedance select , ideas welcome
andre tchmil
land of chicon
Hi all.
Need to rack some preamps and I'm using the JLM go between kit for the project.
Preamps do have a phase switch on board, so I was thinking if I could use the existing JLM phase switch as an 150/600 ohm impedance switcher. Ideas very much welcome.
not really practical, as jlm phase is 'hardwired' using pcb traces. I would recommend to leave the jlm phase switch (and the hole on the front panel) out altogether and jumper off the relevant parts of the go-between pcb. add an impedance switch off-board, which you can insert either before or after the go-between.
You have a point there, but since the spacing for 3 switches is already there...
