Looking for 1G resistors for the Dorsey Oktava MC012 mod
[quote author="Category 5"]Wont a 3/4 or 1w piece intorduce added current drain?[/quote]
no.
[quote author="Category 5"]I meant a physically bigger part, but 1/4 watt.[/quote]
A resistor's size and power dissipation rating are one and the same (the bigger the part, the more surface area it has in contact with the air to dissipate heat.
Peace,
Al.
I read somewhere on here that this would work for the 1gig resistors. I just wanted to post that I got an email saying it is being discontinued.
You have purchased the following part number(s) from Digi-Key within the lasttwo years.
The manufacturer has announced this part(s) will become obsolete.
OHMITE
Description: RES THICK FILM 1000M OHM .50W 5%
Manufacturer Part No: MOX-300001007J
Digi-Key Part No: MOX300J-1000M-ND
[quote author="paxworth"]it is being discontinued.[/quote]
Not really... It's just being replaced for a new RoHS-compliant part (the one we're getting from the Digi-Key groupbuy).
Peace,
Al.
This is the resistor that i used for my Dorsey mod MC012.
This one is 2G with the size of a 1/2 watt.
I got it from NEWARK. they also have 1G values.
Hope this helps.
Part#19C8063
RNX-3/82G00KNL05 VISHAY DALE
http://www.vishay.com/docs/31032/rnx.pdf
I used to use the chip versions of these for cooled IR detector preamps:
http://www.kube.ch/eltec/resistors.php
I had to test them at low (~77K) temps to weed out the really bad ones. I remember one that was metastable in value---with current it would sit there and generate random telegraph signals at roughly a few Hz.
But the approximate value for that one was 10^12 ohms in an 0805 package, so they are probably pretty good parts around a gigaohm.
Brad
Old thread but some good news:
http://se.rs-online.com/web/p/through-hole-fixed-resistors/2477856/
Cheap 1G resistors in Europe.
