R
reanimatorstudio
Guest
Kingston said:GSSL input and output are filled with 100nF bypass caps for the electrolytics. They actually degrade audio signal quality, especially if you have even halfway decent electrolytics. They should be removed.
reanimatorstudio said:Maybe a new GSSL pcb with all the mods like the turbo mod, sidechain mod, ... would be cool
reanimatorstudio said:Quote from: Kingston on September 01, 2009, 05:47:48 pm
Can you tell me how they degrade the signal, is there a theoretical reason for?
LM317 & LM337 are better for noise issues, I don't have any humm problem. Good idea I'm goinig to try that!!
Unsolder the 100kΩ resistor right from the Threshold pot. It should have the same effect as before, but you will have the threshold pot working.
EEMO1 said:i'd like to build one with crush the hell -mod and then wet-dry... just for drums.
Yes, you have to implement the little schematic with the 4 resistors and 2 caps on the other half of the 2-polar switch too
