- Joined
- Jul 11, 2005
- Messages
- 118
Dear DIYers,
during covid I started this monitorcontroller project. I am pretty far into it right now but there are some little problems you maybe can help me with.
First I want to describe the project. It was inspired by igors monitor controller, that unfortunately is not available anymore.
the monitor controller consists of
- a mainframe with all the audio inputs and outputs and the relay matrices and a talkback input/output.
- a remote control connected with ethernet cable to the mainframe that communicates over i2c with the mainframe, it also has a headphone amplifier built into it and houses a metering circuit.
the monitor controller has the following functions:
- switching between sources (4 stereo inputs) and destinations (4 stereo outputs)
- level control over relay attenuator (63steps/1dB)
- mono (with compensation)
- dim (dim level can be user programmed 0 -20dB)
- cut (LR, L or R)
- polarity inverse L and/or R
- LR swap
- Talkback (latching or momentary, user programmable TB-dim)
- 3 user programmabel preset levels for fast access
- 3 digit display
- rotary encoder for level setting and programming
- outputs can be programmed for a certain dimlevel in 0.25dB steps (up to 15dB)
- inputs can be programmed with offset of +-10dB
Problems:
On the picture you can see the remote control module. the lowest 2 bars of the meter leds are iluminated even with no audio signal present. is that a digital crosstalk from the i2c communication? why only on one side?
and I also hear some very low volume clicks in the headphone part (which takes only the + part of the balanced source to the control unit) when I am changing parameters on the monitor controller. What could that be? would it be better to buffer these sends to the remote on the mainframe?
frontside of remote control pcb
some more pics:
rear side of remote control pcb
mainframe pcb in temporary case
- cut (LR, L or R)
- LR swap
- 3 digit display
Problems:
some more pics:
