Hey,
This has been covered in depth in this thread. Go to the top right hand of this window and try searching for "scope bias" in the search bar that says Good for searching within topics.
Here is a quote from one of Dany's posts (found through searching)
"then if you have a scope you can tweak this adjusment by injecting a 1K sine tone trough r6 leg, do not add another probe to the fet gate. then with the red scope probe on the drain pin of the fet and the black on the mic chassis , set the scope so you can see the sinus output from the scope and then increase the amplitude of the signal until the sine wave flat out, the idea of this adjusment is to have the sine flat out equally on both phase at the same time so in short both top and bottom should flat out at the same time as you increase the amplitude of the signal . to see that happen you need to cycle the amplitude of the sine tone up and down while tweaking that drain value until this happens and then you have the optimized bias point."
Dave
Dave
