is that even a good idea to be a single layer only?
I wasn't sure how to put it, as the usual K47 cheaper clones have 2 layers of the backplates?
I meant to say 87!None of the three in that image is a K47 clone.
K67/K87 clones all have a "square grid" of holes; K47's have a concentric-circle pattern of holes in the backplate.
That's a instant buy! I'm a huge sucker for takstar anythingThis is from takstar. Interesting single back plate capsule with no chamber. I remember it sounding pretty decent?
Thanks. I'll check it out.It is unique capsule, single backplate, k67. I appreciate it for being unique. It has frequency response kind of in k67 ballpark, but pattern response similar to k47.
I modified one here, you can see the frequency response before and after the mod.
https://groupdiy.com/threads/k67-capsule-mod-for-less-high-end.76972/
If that is the response in anechoic chamber why is there so much smoothing, and why isn't it accurate below 100hz?Oh, I have also used this one before, and the frequency response in the anechoic chamber is about this. It is not very accurate below 100HzView attachment 114652
You are correct, but I’m failing to see the connect here. I may have missed something.Do I undestand wrong but Martin Kantola has aluminum in his exelent mics. Sorry my lack of....
Actually, most anechoic chambers below 100HZ are not very accurateIf that is the response in anechoic chamber why is there so much smoothing, and why isn't it accurate below 100hz?
Wouldnt that mean the measurement is not valid then?Because it is not a particularly standard anechoic chamber and there are not many sampling points, this curve has been smoothed, but it is also relatively accurate and can be referenced
So what kind of measurement results are valid? The results vary under different test variables, and the test curve can only be used as a reference. Each product test has its own differences, and this data may not be qualified as an accurate measurement, but it is not a problem to use it as a referenceWouldnt that mean the measurement is not valid then?
