OK - I should then mention that some of the new High Quality OpAmps has some very good Build-In protection - like TI's OPA1678 .... Unfortunately it hasn't been in stock since the Chip Chrisis started during Covid
I also has quite a bit of experience with TVS Diodes - most of them NOT good - Here it is Very Important to notice, that this is not the TVS to blame - but the designer, who choose to install ones that where too small.
Later they got changed to some with Much bigger capacity (not capacitance, but Current/Energy) - Easy to see, as they are in a house more than a factor 100 bigger in volume. After that I only saw one I had to change ...!
All where placed across the pins on a XLR DI Output - and I'm pretty sure they died when the House Mixer and the Bass Amp on Stage, where on different Phases (+ likely other faults) in the Mains Installation => 400Vac + Amps ....
About half the time, I saw the OpAmps had survived as the TVS stayed permanently Shorted after the Fact - and the other half had Visible Fault-Finding
(ie. burned holes in the plastic over the chip). The major good thing, was that with one exception, the rest of the Bass Amp survived.
