a pint of beer over my 100W PA amp whilst we were playing in a pub, one hot Mullard EL34 went out with a blue flash, I was lucky it didn't get the other three.
DaveP said:If you can't get any better than that, then as Alan says, you can only reduce the current draw by increasing the cathode resistors, say from 330 to 360 or 390. It won't affect the perfomance at all.
There is another possibility; check the current through each output tube and make sure they are in reasonable balance. If there is excessive current with no signal then there is an ultrasonic oscillation drawing extra current, check with scope.
hope that helps
best
Dave
David Kulka said:The BA-6A I tested had its power transformer set to the 115 volt line tap so I ran it plugged into a variac set for exactly 115 volts output. I interrupted the wire connected to the output of L1 and inserted a Fluke 8060A to measure current, and your estimate was right on -- DC current was 124 ma. I also measured the small AC current component at this point (before C117), it was about 2.5 ma.
DC voltage at the choke input was 340; at the choke output it was 318. Hope that helps, and good luck to all with this project! A BA-6A, working right, is a fantastic limiter.
Not sure why I've got such a difference on pin 3 between the two 6J7 tubes. That could be because I'm using CC resistors with varying tolerances. Does this worry anyone?
although if I could raise the B+ it looks like a lot of the low voltages would creep closer to the ideal.
Must be something drawing a lot of current.
how do I check the current draw of the 6V6s?
If the B+ raises by 30v, won't the rest of the voltages that are fed by the B+ via a dropping resistor also rise by 30v?They will go slightly lower if that's what you mean.
Great, thank you.With single cathode resistor - you have voltage drop there. Ohm's law gives you the figure you need.
Good idea, I'll see if Maplin has the 1N4007 in stock. I bought the rectifier from Jim at Vacuum Tubes Inc, so I'd be surprised if it was a bad tube, but hopefully this will rule it out.If you have got 520V rms ac across the rect tube anodes, with perfect diodes you would have 369V dc, but you have got a voltage drop of 114V which is way too much. A good check would be to sub the 5R4GY with a couple of 1N4007 and see what you get. If its nearer to 369V then you have been sold a clapped out rectifier tube. Re check all the transformer rect/choke wiring just in case.
Unforetunately I don't have an extra pair to try, so I might try raising the cathode resistors.Do you have a couple spare sets of 6V6s lying around ? If so, try subbing them for the current pair and see how much things change.
I'm using the original input and output TX, but the Sowter interstage.Are you using the original OTs? Reason I ask is that they likely have relatively high DCR which may be a good bit higher than say the Sowter drop ins. So there is some upstream dropping resistance in the original which causes the 6V6s to pull a little less current than if you assumed the OT DCR negligible.
DaveP said:If you have got 520V rms ac across the rect tube anodes, with perfect diodes you would have 369V dc, but you have got a voltage drop of 114V which is way too much. A good check would be to sub the 5R4GY with a couple of 1N4007 and see what you get. If its nearer to 369V then you have been sold a clapped out rectifier tube. Re check all the transformer rect/choke wiring just in case.
That does seem like they're pulling huge amounts of current to me.
I've just tried running some tone through the unit and I lose the signal at the output of the input tx. Is this normal? I have a heralthy 1k sine wave on the primary, and nothing on the secondary...
My input transformer is actually from an 86A. Looking at the schematic for the 86A it looks like it has pins 11 & 5 tied to ground which I haven't done on mine. I'll solder them together and report back.
Unfortunately I didn't measure the RMS when I had the diodes installed.I'm beginning to wonder if your power TX is up to the job of running a tube rectifier. I take it that your RMS voltage across the diodes is now~455V? Now the resistance of the rect tube has gone it is drawing more current from the TX and volts have dropped. Are there any other choices of input voltage tappings? Like 220/230/240V? If so you could move to a lower one to boost the secondary voltage.
I turned up the input and the output to max (with nothing running through it) and I could just hear a tiny amount of hiss.
I've just run a random drum loop through it and it sounds great!
