AdrienPerinot
Member
I took the opportunity to measure different preamps (new SSL ones, Focusrite Scarlett, Warm Audio TB12), and investigate a bit on the topic of "audible differences between preamps".
If we run the preamps too hot, I came to the following conclusions :
Everyone seems to hear punch and smoothness differences, and I feel I hear them too, but where does it actually come from ? Has anyone been able to 'demonstrate' that ?
Adrien
- The preamps are usually rather flat in terms of frequency. At least nothing that couldn't be fixed with some basic digital EQing. Example : Measurement of an API312 here on SoundOnSound
So it seems unlikely that frequency response is really what differs between preamps. - The harmonics are of course different, in the case of transformer-balanced preamps. But they are usually at a rather subtle level (unless the preamp is pushed).
- The slew rate of the preamp usually seems to allow for a correct reproduction of all the audible frequencies.
- Why would a preamp like the API be called "punchy" ? What would "punch" be ?
- If it's a variation of the transients (we hear about "slow" vs "fast" preamps), then where does it come from if the slew limit is > 20000 Hz ? The transformer ? If so, aren't the transformers supposed to be rather transparent, harmonics put aside for the lower frequencies, in the frequency range ?
- Would the slew rate, if a bit too low, be able to influence the audible frequencies (even if the amplifier would, on paper, be able to reproduce those frequencies without any problem) ? It seems so : https://hifisonix.com/wp-content/uploads/2018/03/SID_and_TIM_W_Jung_77-79.pdf
- Did I miss any phenomenon ?
Adrien
